zhangzq71
what's wrong with this logic?
Here is my program,
	always @(posedge M_AXI_ACLK)
	begin
		if (M_AXI_ARESETN == 0 || LOCAL_RESET == 1'b1)
		begin
			start_write_addr <= 1'b0;
			fifo_read_en <= 1'b0;
			wr_ddr_en <= 1'b0;
			state_sm2ddr[2:0] <= S_WR_IDLE;
			run_cnt1 <= 0;
			run_cnt2 <= 0;
		end
		else
		begin
			case (state_sm2ddr)
				S_WR_IDLE:
				if (SM2DDR_FIFO_WR_COUNT >= C_M_AXI_BURST_LEN)
				begin
					if (~burst_write_active && ~start_write_addr)
					begin
						run_cnt2 <= run_cnt2 + 1'b1;
						fifo_read_en <= 1'b1;
						state_sm2ddr[2:0] <= S_WR_WAIT_FIFO;
					end
					else
					begin
					end
				end
				else
				begin
				end
				S_WR_WAIT_FIFO:
                begin
					start_write_addr <= 1'b1;
					state_sm2ddr[2:0] <= S_WR_WAIT_WLAST;
                end
				S_WR_WAIT_WLAST:
                begin
					if (axi_wlast)
					begin
						state_sm2ddr[2:0] <= S_WR_NULL_STEP;
					end
					else
					begin
					end
                end
				S_WR_NULL_STEP:
				begin
					run_cnt1 <= run_cnt1 + 1'b1;
				end
				default:
				begin
				end
			endcase
		end
	end
As you can see run_cnt1 + 1 must occurs after run_cnt2 + 1, so run_cnt1 must be equal run_cnt2, but in my test run_cnt1 is greater than run_cnt2, what is wrong?
zhangzq71
Great! You must be an AXI expert, and made som many IP cores. I think AXIS2MM and AXIMM2S will be useful to me.
I am very glad to know you and thank you very much showing me your very useful cores.
hgleamon1
I don't understand what you mean by "second" or "third" time. How are these different to running "first" time after power up?
What happens in between "first", "second" and "third"?
"That which we must learn to do, we learn by doing." - Aristotle
zhangzq71
Sorry to make you so confused.
What I want to say is,
1. after upload the bitstream to PCIe card, I turn off the computer
2. turn on the computer
3. load the PCIe driver in linux
4. then run a program to send 0x80000 to a register in PCIe to tell it needs to process 0x80000 bytes data
5. then code I sent you will be executed
6. I checked the result, everything is ok, run_cnt* are all correct. This is first time.
7. I repeat step 3-6, that is the second time. the same error occured as before. then I turn of the computer.
I repeat step 2-7 for 3 times, everytime the result is OK in step 6 and failed in step7.
Do you understand what I say?
hgleamon1
Yes, I understand your method. thank you for the clarification.
Why do you reload the driver in Linux? What happens if you simply rerun the program without reloading the driver?
zhangzq71
sorry, my mistake, it should be "I repeat step 4-7 for 3 times"
zhangzq71
Sorry,
"I repeat step 2-7 for 3 times, everytime the result is OK in step 6 and failed in step7." is correct, because the computer had been turn off at step 7.
so I must need to load the driver again after the system boot up.
zhangzq71
Oh, sorry, I am confused.  :-)
"7. I repeat step 3-6, that is the second time. the same error occured as before. then I turn of the computer.", it should be "7. I repeat step 4-6, that is the second time. the same error occured as before. then I turn of the computer."
That means it did not reload the driver in the second time.
