xapp1052 on Ubuntu
I've tried to compile the linux xbmd GUI in Ubuntu 10.04.
I'm running the 'run_bmd.csh' script from bash as root (using 'sudo bash').
I keep on getting this error message:
gtk-builder-convert xbmd_app.glade xbmd_app.xml
WARNING: duplicate id "menuitem"
WARNING: duplicate id "new_menu_item"
Wrote xbmd_app.xml
make -C /lib/modules/2.6.32-22-generic-pae/build M=/root/xbmd  modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-22-generic-pae'
scripts/Makefile.build:44: /root/xbmd/Makefile: No such file or directory
make[2]: *** No rule to make target `/root/xbmd/Makefile'.  Stop.
make[1]: *** [_module_/root/xbmd] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-22-generic-pae'
make: *** [all] Error 2
crw-r--r-- 1 root root 241, 1 2010-05-07 15:04 /dev/xbmd
+ /sbin/insmod xbmd.ko
insmod: can't read 'xbmd.ko': No such file or directory
Any suggestions ?
cheers,
Issue resolved,
I forgot to copy the xbmd directory to '/root'
Sorry for the disturbance.
