xupv5lx110t not detected using Bus Master DMA (xapp1052)
I have a xilinx xupv5lx110t (ML509) and I am following the xapp1052 doc. I need to comunicate via PCIe using DMA.
I could succesfully detect and test my board with the PIO exemple (as discribed on xapp1022). But now I need a faster comunication.
With BMD i can actually generate the bitstream but my board is not detected by lspci.
with PIO design lspci returned the board on position 0000:04 but now, after loading the bitstream and a warm reset, dmesg returns:
[    1.153636] pci_bus 0000:04: resource 0 io:  [0x3000-0x3fff]
[    1.153638] pci_bus 0000:04: resource 1 mem: [0xc0800000-0xc09fffff]
[    1.153639] pci_bus 0000:04: resource 2 pref mem [0xc0a00000-0xc0bfffff]
If I try loading the driver xbmd.ko from xapp1052, I get this:
insmod: error inserting 'xbmd.ko': -1 Operation not permitted
and dmesg returns:
[  582.230245] xbmd: Init: Hardware not found.
My bitfile was generated by ISE10.1 and UBUNTU 10.04
I would really apreciated some help.
Eduardo
You could try comparing the xco file from the working pio example design and the non-working bmd design. The significant difference between the two is the back end user design. Therefore if one is working then the other one should also be detected correctly provided the required parameters such as sub-class code etc. are similar.
Anonymous
Not applicable
    I'm facing almost the same problem, but using Xilinx Virtex-6 DSP Development Kit with High-Speed Analog (ml605). Below are script and dmesg outputs:
[root@cpqd051342 xbmd]# ./run_bmd.csh
gtk-builder-convert xbmd_app.glade xbmd_app.xml
Wrote xbmd_app.xml
make -C /lib/modules/2.6.27.5-117.
fc10.x86_64/build M=/root/xbmd  modules
make[1]: Entrando no diretório `/usr/src/kernels/2.6.27.5-117.fc10.x86_64'
 Building modules, stage 2.
 MODPOST 1 modules
make[1]: Saindo do diretório `/usr/src/kernels/2.6.27.5-117.fc10.x86_64'
g++ -Wall -g -o xbmd_app cfg.cpp bmd.cpp xbmd_ep.cpp xbmd_main.cpp
`pkg-config --cflags --libs gtk+-2.0 --libs libglade-2.0`
-export-dynamic
crw-r--r-- 1 root root 241, 1 Nov 30 16:35 /dev/xbmd
+ /sbin/insmod xbmd.ko
[root@cpqd051342 xbmd]# dmesg
xbmd: Init: Base hw val 0
xbmd: Init: Base hw len 1024
xbmd: Init: Virt HW address 33C000
xbmd: Init: Device IRQ: B
xbmd: Init: Memory in use.
    What could be the problem?
I am facing a similar problem, Is there any solution? xbmd.ko file is missing
here is the log of linux command
./run_bmd.csh
make: gtk-builder-convert: Command not found
make: *** [all] Error 127
crw-r--r-- 1 root root 241, 1 Mar  3 15:08 /dev/xbmd
insmod: can't read 'xbmd.ko': No such file or directory
Best Regards,
Uzair
