Creating a Pico Blaze
I configured my Spartan 3 E Starter Kit for the first
time few weeks ago.Now, while I am still studying VHDL
I am planing to creat a PicoBlaze in my FPGA. I have a
VAIO laptop without parallel port. What do I have to do to
configure the FPGA without a parallel port ?
Please give me generous details as I am a beginner .
Thank you
BENEDITO
bassman59
Historian
Historian
If you had read the S3E Start Kit's user guide, you would know that the board has a built-in JTAG configuration block, which is the same circuit as the Platform Cable USB. It has a USB connection to your computer. Why did you think that you needed a parallel port?
(BTW, the title of your message should not be "creating a Pico Blaze," it should be something like "Spartan 3E Start Kit Configuration.")
What I really want to do is   configure a Pico Blaze in my Spartan 3 E Starter Kit.
Can I do that using only the USB cable ?
By the way : Can I do multi boot in the Master Serial xcf 04 s flash PROM ?
bassman59
Historian
Historian
RTFM. A PicoBlaze processor is a part of a larger FPGA design.  Once that design is synthesized and implemented and a binary configuration image is created, then yes, you can program the configuration EPROM on that board using the USB connection.
I don't know. What do the data sheets and the user guides say?
vijayak
Moving to Picoblaze board
Thanks,Vijay
chapman
The following site contains multiple reference designs presented on the Spartan-3E Starter Kit and 13 of those contain PicoBlaze.
http://www.xilinx.com/products/boards/s3estarter/reference_designs.htm
Ken Chapman
Principal Engineer, Xilinx UK
I discovered this tutorial in the web.
Spartan3E_Tutorial_2 Introduction to using the PicoBlaze Microcontroller
Jasmine Banks
Many useful information  like use DOS BOX  for  64 bit  Wind 7
