nikoiv
divide clock by 13.5 circuit
In the documentation accompanying the 6 release of microprocessor Picoblaze, Ken Chapman gives an example, which illustrates the operation of the UART module (UART6_User_Guide_and_Reference_Designs_29March13.pdf).
Particularly attractive to me was the idea that suggests how to build a frequency divider for 115200 baud UART module mode operation, from system frequency 25MHz.
I realize this idea of a low level. This code is used successfully for 2 months in a several projects, implemented in the kit with systemic frequency 25MHz.  I think it will be pleasant for the users of the forum.  Here it is:
-- Engineer: Nikolay Ivanov
-- Create Date:    04/17/2013
-- Module Name:   Baud_rate_Timer - Low level definition
-- Project Name:          Baud_rate 115200
-- Target Devices:  XC6
-- Tool versions: Xilinx WebPack ISE 14.4
-- Description: Generates a Baud rate pulses in order to perform 115200 baud communication
--              from system frequency of 25  MHz.
-- Dependencies:
-- Revision: 0.01 - File Created
-- Library declarations
-- Standard IEEE libraries
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library UNISIM;
use UNISIM.VComponents.all;
entity Baud_rate_Timer is
    Port (  En_16_x_baud : out std_logic;
                     clk : in std_logic);
    end Baud_rate_Timer;
-- Start of test architecture
architecture Low_level of Baud_rate_Timer is
signal a1,a2, a3 : STD_LOGIC := '0';
-- Start of circuit description
begin
SRL16E_inst1 : SRL16E
generic map (INIT => X"0001")
port map (Q => a1,
                                     A0 => '0',
                                     A1 => '0',
                                     A2 => '1',
                                     A3 => '1',
                                     CE => '1',
                                     CLK => clk,
                                     D => a2 );
SRL16E_inst2 : SRL16E
generic map (INIT => X"0000")
port map (Q => a2,
               A0 => '1',
               A1 => '0',
               A2 => '1',
               A3 => '1',
               CE => '1',
            CLK => clk,
                 D => a1 );
LUT2_inst : LUT2
generic map (INIT => X"E")--or2
port map (O => a3,
                I0 => a1,
                I1 => a2 );
FDCE_inst : FDCE
generic map (INIT => '0')
port map (Q => En_16_x_baud,
     C => clk,
  CE => '1',
           CLR => '0',
                D => a3 );
end Low_level;
-- end of Baud_rate_Timer module
Success!
gszakacs
Professor
Professor
This is exactly the reason why I think the idea of using a 16X baud clock for a UART
makes no sense in an FPGA with all its resources.  My own UART incorporates
the baud divider, and samples at the input clock rate, in this case 25 MHz.  Then
the oversampling rate is just clock frequency divided by baud rate, in this case 217.
This gives a very tight baud rate tolerance as well as allowing for sampling very
close to the center of the bit period.  Of course this necessitates a longer baud
divider within the UART but eliminates the (jittery) external clock divider that would
of necessity be in the FPGA also.
-- Gabor
nikoiv
Gabor, I do not know your uart module. But I agree with you that the accuracy obtained by dividing 25 MHz to 217 is very high. (0.006%). The objective pursued by the proposed solution is to achieve frequency which after division of 16 allow to the communication module to operate in 115200 baud mode. The accuracy achieved with the proposed solution is near 0.47%, which in practice is more than enough. And because theoretically the divider can be realized within a slice, it becomes a minimax solution I think.
vremmers
Nikolay,
Thankyou for providing this divide by 14,13,14,13...
It seemed a little more complex than necessary.
I made a few changes
Changed to use SRL16 instead of SRL16E as the CE was not used
(would not reduce resources used, but simplifies the source)
Changed both SRL16 to have INIT of 0001 and removed LUT2
(reduces resources used by no longer needing a 2 input LUT)
Changed to use FD instead of FDCE as neither CE or CLR were used
I can not see why the output flip-flop is needed, but in the
White-Paper WP271, Mr. Chapman states:
"The flip-flop ensures high performance, as such an enable pulse may have a high fan-out.".
Is this implying that a flip-flop can fan-out to a larger number
of inputs, or does the synthesis replicate this output flip-flop
based on the number of inputs it needs to fan out.
Vince
-- Dependencies:
library IEEE;
library UNISIM;
signal a1,a2 : STD_LOGIC := '0';
begin
port map (Q => a1,
         A0 => '0',
         A1 => '0',
         A2 => '1',
         A3 => '1',
        CLK => clk,
          D => a2 );
port map (Q => a2,
         A0 => '1',
         A1 => '0',
         A2 => '1',
         A3 => '1',
        CLK => clk,
          D => a1 );
FDCE_inst : FD
          C => clk,
          D => a1 );
end Low_level;
chapman
If, for example, we look in the Kintex-7 data sheet (DS182) we can see that for a -1 speed grade the clock to output time of a dedicated flip-flop (TCKO) is 0.32ns but the clock to output time of an SRL 16 (TREG) is 1.2ns. So when you use a dedicated flip-flop there is 0.88ns more time available for the routing of the signal and that just makes it easier to route a signal a longer distance and/or fan out to more loads. It is not about the drive strength of the CLB output; only the difference in delay.
Ken Chapman
Principal Engineer, Xilinx UK
vremmers
Mr. Ken (Constant with a 'K', wink) Chapman,
Thankyou for explaining this.  I understand this much better now.  By looking at the timing diagram on the next page (WP271
page 14),  I see that the flip flop is effectively providing an extra shift register bit, outside the circular shift register in the SRL16.
The outgoing pulse is one clock cycle delayed, except the transition edge of the Q output is much closer to the transition
edge of CLK, than it would have been if the output Q of the SRL16 could have been used directly.
I am actually currently using a Spartan3AN, "-4" grade, and the difference is even more pronounced than the example
you gave.
TCKO Flip-Flop, Time from clock transition to output on Q = 0.68ns
TREG Shift Register, Time from clock transition to output on Q = 4.82nS
Thankout
Vince
vremmers
Also note:
If you are using a Spartan6, the shift registers and be configured as 32 bits, and so this could be
done with one shift register and one flip-flop
signal a1 : STD_LOGIC := '0';
begin
SRL32_inst : SRLC32E
generic map (INIT => X"00004001")
port map (Q => a1,
        Q31 => open,
          A => "11010",
        CLK => clk,
         CE => '1',
          D => a1 );
FD_inst : FD
          C => clk,
          D => a1 );
end Low_level;
