100 Mb/s Ethernet using Zynq Ultrascale+ GEM
I would like to be able to use GEM0 in 100 Mb/s mode with Linux with auto-negotiation. Currently I'm using a 5.2 kernel, but using the xilinx zynqmp-clk-ccf.dtsi instead of the mainline zynqmp-clk.dtsi. Normally this is broken, but I was able to track down what is going on.
In the Linux macb driver clk_set_rate() is called with a rate depending on what speed was negotiated. This ultimately calls zynqmp_pm_invoke_fn(PM_CLOCK_SETDIVIDER,...) This is now handled by the ATF, which in turn sends the request to the PMU in PmProcessRequest() case PM_CLOCK_SETDIVIDER which calls PmClockSetDivider(). In PmClockSetDivider() there is a permission check with PmClockCheckPermission() this can be disabled with DISABLE_CLK_PERMS.
So setting DISABLE_CLK_PERMS to (1U) in xpfw_config.h fixes this problem for GEM0, Hooray!
However there is a note in xpfw_config.h that says "(it is not safe to ever disable clock permission checking). Do this at
* your own responsibility.". So how can the permissions be set correctly so Linux can set the rate using this divider (as the driver clearly needs to do)? I did not see any option for this in Vivado 2019.1 where the pmufw is generated from?
I don't see any Errata or mention of this problem on the macb driver page. Is there any other background info or info on what the plan from Xilinx is?
thanks,
Paul
We are using MYIR's MYD-CZU3EG board and has some experience, maybe you can try to modify the clock of gem from 125MHz to 25MHz in vivado clock configuration. Hope it would be helpful.
