Anonymous
Not applicable
APU problem in interrupt handler
I'm using the ML403 board for the interrupt-based system. In this system, floating point operations in interrupt handler are required and APU is employed to accelerate the single precision floating point operation. The software is running with the standalone BSP on the PPC. The snippet is shown below:
        // global variables
        static float a=1.0F;
        static float b=2.0F;
void TimerCounterHandler(void *CallBackRef, Xuint8 TmrCtrNumber)
        a += b;
It seems that PPC is blocked when timer interrupt handler “TimerCounterHandler” is executed. Any advice on how to resolve the problem?
Thanks!
Anonymous
Not applicable
It can be done by adding
"mtmsr(mfmsr() | XREG_MSR_FLOATING_POINT_AVAILABLE);"
to the interrupt handler.
Please refer to
http://www.fpgarelated.com/usenet/fpga/show/88349-1.php
Best Regards,
max_xilinx
chris_basson
We also ran into a similar problem, it does not seem possible doing it that way, refer to
http://www.xilinx.com/support/answers/29948.htm
Best regards,
Chris
Anonymous
Not applicable
Please refer to
Best Regards,
max_xilinx
chris_basson
Thanks, sounds simple enough - we will be giving it a try too,
Best regards,
Chris
