vikaskanha
AXI DMA LOOPBACK TEST WITH MICROBLAZE
Hello all,
I am trying to add (AXI DMA + AXI-4 DATA FIFO) in microblaze. But i am not getting where to connect M_AXI_MM2S and M_AXI_S2MM. Currently i have connected M_AXI_MM2S and M_AXI_S2MM to AXI interconnect. I want to write in fifo  using dma and read it back using dma. Below i am attaching my block design.Is my design correct?. Where i will get the address of FIFO.
Thanks & Regards
