AXI DMA stream width
I need to set the stream data width of the S2MM interface in the AXI-DMA IP. The parameter appears fixed at 32 bits but in
old versions if Vivado the width could be modified according to the block connected to the AXI-DMA IP.
In 2017.4 the data width remains always at 32 bits giving a mismatch critical warning. Is there any way to solve the problem
when the blocks to connect have different data size (ex. 8 or 16 bits )?
GS
Mentor
Mentor
Try using an AXI-Stream Data Width converter on the 32 bit stream interface to the DMA
Mentor
Mentor
Thank you very much. It works :)
