hbelatikar
AXI GPIO Memory Read Error at GPIO address
I'm trying to output a data on an AXI GPIO memory mapped pin, but whenever I try to Xil_Out32() on their address I get stuck in a DataAbortHandler loop.
I have already added the memory address in my block design and I can also see the address in the xparameters.h file
The first 7 AXI GPIO pins (0x4120_0000 to 0x4126_0000) are working fine. Only the last two pins (0x4127_0000 and 0x4128_0000) are facing this problem. I recently update my design by adding the last two pins but I do not understand which step I've missed.
If the addresses are appearing in the xparameters.h files then why am I unable to read from them.
Any help would be appreciated.
hbelatikar
stephenm
The issue could be HW, if the IP are held in reset, or not clocked correctly then you will not be able to access them either.
To rule out a SW issue. you could try the XSCT/XSDB and do a mrd here to verify if this works
hbelatikar
I was facing this issue when I had copied over my Vitis workspace inside my Vivado project directory for better version control.  After going back to my original workspace, the GPIOs started to work fine.
Is there a proper process to change workspace directories? I exported the Vitis project and imported it to the new directory I had created.
I tired to do the mrd using the xcst/xsdb but it gave me the same error.
