josephsamson
AXI IIC Not Addressed As Slave
I am trying to detect the repeated start as an AXI IIC slave so that an IIC master can read data from the slave. I have successful slave reads when I use two cycles: a master write that begins with a start condition and ends with a stop condition, followed by a master read that begins with a start condition and ends with a stop condition.
Now I want to have a master write that begins with a start condition and ends with a start condition (the repeated start), followed by a master read that ends with a stop condition. When I generate this IIC bus traffic, the IIC Status Handler reports Event 16,  XII_MASTER_WRITE_EVENT, but the receive handler is never called.
xiic.h indicates that the Not Addressed As Slave interrupt should call the receive handler:
* The Not Addressed As Slave interrupt is not passed directly to the
* application thru the status callback.  It is used to determine the end of
* a message being received by a slave when there was no stop condition
* (repeated start).  It will cause the receive handler to be called to
* indicate completion of the operation.
I don't see this happening. The receive handler is not being called.
Is there some additional step that I should be taking to enable the repeated start detection?
Joe Samson
josephsamson
Solved another one.
The AXI_IIC example iic_slave_example.c includes the following code:
while ((ReceiveComplete) || (XIic_IsIicBusy(&IicInstance) == TRUE)) {
	if (SlaveRead) {
		XIic_SlaveRecv(&IicInstance, ReadBuffer, RECEIVE_COUNT);
		SlaveRead = 0;
Looping while XIic_IsIicBusy is true will work with a slave receive that ends with a stop condition, but it loops forever when the slave receive ends with a repeated start. When I remove the loop, my the slave receive with repeated start works.
Joe
josephsamson
A little more information from debugging:
I put a print statement in the AddressedAsSlaveHandler and in the NotAddressedAsSlaveHandler.
When the master writes to the slave (my design is the slave), the following occurs:
1. AddressedAsSlaveHandler (corresponding to the I2C Start)
2. I2C Status Handler, XII_MASTER_WRITE_EVENT
3. NotAddressedAsSlaveHandler (corresponding to the I2C End)
4. I2C Receive Handler
When the master reads from the slave, the following occurs:
2. I2C Status Handler, XII_MASTER_READ_EVENT
4. I2C Send Handler
However, when I try a master read from slave with repeated start, the following occurs:
The repeated start does not trigger the NotAddressedAsSlaveHandler
Joe
josephsamson
Solved another one.
	if (SlaveRead) {
		SlaveRead = 0;
Joe
