painkil
AXI IIC Pulse Train after NACK
I'm using AXI IIC module with Microblaze in Vivado 2018.3.
I have a problem in resetting target slave device which have 0x70 of slave address.
When I write some data to I2c Slave Target to reset that device.I got SCL pulse train until I reset I2c bus. this causing I2c Bus Busy and errors.
STOP conditions not coming even that I scheduled to write STOP command to TXFIFO (0x108) with 0x280 (0x200 is STOP Command in AXI IIC module)
Please tell me if there anything that I have to reset this state.
ritakur
Please make sure you don’t disable the IIC when trying to flush the FIFO.
