vivienwwp
AXI Quad SPI
  I've added the AXI Quad SPI into my design but when I tried to debug in Xilinx SDK. I don't see the module. Is that normal?
Also, I've selected the SPI module to be a slave and it is polling to receive data (1 byte) from an external micro (master). However, my code gets stuck within XSpi_Transfer(). Could you let me know if my code will work?
Thank you very much
ConfigPtr = XSpi_LookupConfig(SPI_DEVICE_ID);
	if (ConfigPtr == NULL) {
		return XST_DEVICE_NOT_FOUND;
	status = XSpi_CfgInitialize(&Spi, ConfigPtr, ConfigPtr->BaseAddress);
	if (status != XST_SUCCESS) {
		//return XST_FAILURE;
	else if (status == XST_DEVICE_IS_STARTED)
		// device is started then stopped it and re-initialize
		XSpi_Stop(&Spi);
				return XST_FAILURE;
			return XST_FAILURE;
		 // Start the SPI driver so that interrupts and the device are enabled
		XSpi_Start(&Spi);
			return XST_FAILURE;
		XSpi_IntrGlobalDisable(&Spi);
		WriteBuff[0] = 0x55;
		status = XSpi_Transfer(&Spi,WriteBuff,ReadBuff,1);
			return XST_FAILURE;
venui
I want to verify the Vivado configuration,Could you please share your desing along with the schematics.
Thanks & Regards,
Venu
vivienwwp
Hi Venu
I've got this resolved. I turned on Master mode on my block design in Vivado and should have unchecked it to make it a slave.
