yeeyangtan
AXI Stream DMA does not go into interrupt routine for receiving data
My hardware connection is shown:
My program is written:
#include "xparameters.h"
#include "xil_io.h"
#include "xil_exception.h"
#include "xaxidma.h"
#include "xscugic.h"
int flag = 1;
void axidma_receive_interrupt_handler(void *call_back_ref)
	int status;
	XAxiDma *inst_axidma = (XAxiDma*) call_back_ref;
	xil_printf("Receive interrupt\n");
	u32 *rx_buffer = malloc(sizeof(u32)*10);
	status = XAxiDma_SimpleTransfer(inst_axidma, rx_buffer, 10*4, XAXIDMA_DEVICE_TO_DMA);
	if (status == XST_SUCCESS)
		xil_printf("transfer success\n");
	else
		xil_printf("transfer fail\n");
	for(int i = 0; i < 10; i++)
		xil_printf("rx_buffer[%i]=%x\n",i, rx_buffer[i]);
	flag = 0;
void axidma_transfer_interrupt_handler(void *call_back_ref)
	xil_printf("Transfer interrupt\n");
int setup(XAxiDma *inst_dma, XScuGic *inst_gic)
	int status;
	XAxiDma_Config *cfg_dma = XAxiDma_LookupConfig(XPAR_AXIDMA_0_DEVICE_ID);
	status = XAxiDma_CfgInitialize(inst_dma, cfg_dma);
	if (status != XST_SUCCESS){
		xil_printf("Error: XAxiDma_CfgInitialize\n");
		return status;
	XScuGic_Config *cfg_gic = XScuGic_LookupConfig(XPAR_SCUGIC_0_DEVICE_ID);
	status = XScuGic_CfgInitialize(inst_gic, cfg_gic, cfg_gic->CpuBaseAddress);
		xil_printf("Error: XScuGic_CfgInitialize\n");
		return status;
	XScuGic_SetPriorityTriggerType(inst_gic, XPAR_FABRIC_AXI_DMA_0_MM2S_INTROUT_INTR, 0xA0, 0x3);
	XScuGic_SetPriorityTriggerType(inst_gic, XPAR_FABRIC_AXI_DMA_0_S2MM_INTROUT_INTR, 0xA0, 0x3);
	status = XScuGic_Connect(
			inst_gic,
			(Xil_ExceptionHandler)axidma_transfer_interrupt_handler,
			&inst_dma
		xil_printf("Error: XScuGic_Connect - XPAR_FABRIC_AXI_DMA_0_MM2S_INTROUT_INTR\n");
		return status;
			inst_gic,
			(Xil_ExceptionHandler)axidma_receive_interrupt_handler,
			&inst_dma
		xil_printf("Error: XScuGic_Connect - XPAR_FABRIC_AXI_DMA_0_S2MM_INTROUT_INTR\n");
		return status;
	XScuGic_Enable(inst_gic, XPAR_FABRIC_AXI_DMA_0_MM2S_INTROUT_INTR);
	XScuGic_Enable(inst_gic, XPAR_FABRIC_AXI_DMA_0_S2MM_INTROUT_INTR);
	Xil_ExceptionInit();
	Xil_ExceptionRegisterHandler(
			XIL_EXCEPTION_ID_INT,
			(Xil_ExceptionHandler)XScuGic_InterruptHandler,
			(void *)inst_gic);
	Xil_ExceptionEnable();
	return XST_SUCCESS;
int main()
	xil_printf("-----------------------\n");
	xil_printf("Start\n");
	int status;
	XAxiDma inst_dma;
	XScuGic inst_gic;
	status = setup(&inst_dma, &inst_gic);
	XAxiDma_IntrDisable(&inst_dma, XAXIDMA_IRQ_ALL_MASK,
						XAXIDMA_DMA_TO_DEVICE);
//	XAxiDma_IntrEnable(&inst_dma, XAXIDMA_IRQ_ALL_MASK,
//							XAXIDMA_DMA_TO_DEVICE);
	u32 *tx_buffer = malloc(sizeof(u32)*10);
		tx_buffer[i] = i;
	status = XAxiDma_SimpleTransfer(&inst_dma, tx_buffer, 10*4, XAXIDMA_DMA_TO_DEVICE);
	else
	while(flag);
	xil_printf("End\n");
	return XST_SUCCESS;
 However, I cannot go into the interrupt routine of the function "axidma_receive_interrupt_handler".
This is the result that I get:
Spoiler
Start
transfer success
I would like to make the program jump into the interrupt routine to read the data from dma, and this interrupt routine is triggered by the hardware (dma).
How can I solve this problem?
abommera
Hi @yeeyangtan ,
Have you tried with Xilinx provided simple interrupt example?
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/axidma/examples/xaxidma_example_simple_intr.c
Thanks & Regards
Anil B
abommera
Hi @yeeyangtan ,
Thanks & Regards
Anil B
