bbinb
AXI Uartlite baud rate tolerance
I couldn't find any information about the tolerance percentage of AXI Uartlite IP core.
I mean, if I use an axi uartlite IP with 115200 bps configuration, if the incoming signal is 113000 bps, can the module handle it? Maybe the tolerance rate is related to the AXI clock frequency ?
I can test it to the limits, but if someone knows that would be great.
bbinb
Tags (3)
pvenugo
Hi @bbinb,
Yes in Vivado 2014.2 the UARTlite IP error tolerance is 5% but from 2016.3 it is 3%.
Praveen
pvenugo
Hi @bbinb,
AXI Uartlite from 2016.3 onward have limited baud rate support to avoid baud errors.
Maximum allowed baud error is 3.0% instead of 5 % as baud error calculation logic depends on operational frequency.
We are limiting the baud error tolerance to 3% for the error free operations which we support.
The supported baud rate shows up in IP customization depending on AXI clock selected which works.
For e.g. if AXI clock < 117 MHz you will see UARTlite baud support in IP configuration only up to 230400.
If AXI clock >= 117 MHz the UARTlite baud supports in IP configuration up to 921600.
Praveen
bbinb
Hİ @pvenugo
Thank you very much for the info.
I am using Vivado 2014.2 what I understand is it was 5% but 3% after 2016.3 is it right?
I am using 50 Mhz AXI clock for 115200 bps. Can I assume at least 3% error tolerance? The problem is, my friend implemented a UART module with VHDL and its module couldn't communicate with a device having baud rate of 113000 bps, while I used Zynq and AXI Uartlite and I had no problem with communicating the same device. Then they asked me about the error tolerance rate of my UART module.
bbinb
pvenugo
Hi @bbinb,
Praveen
