giacomo87vett
AXI WLAST strange behaviour in Central DMA transfer
I am working with Central DMA from Xilinx and, during the transfer of 17 words of 32-bit, I noticed, during the simulation, that there are two bursts: one with 16 beats with size 32 bit, and another with 1 beat with size 32 bit.
Looking at the signals behaviours, I noticed that WLAST goes high in correspondance of the 16-th beat of the first burst (that is correct), and that it stucks at WLAST = 1 even if the burst ends and starts the second burst.
Please have a look at the simulation results, attached to this post. The WLAST signal is highlighted in purple. I wounder whether this should be the correct behaviour of the master CDMA.
Thank you for any support,
jg_bds
The behavior is correct. The WLAST signals asserts during the last beat of an AXI transaction. As you've already noted, your overall data movement is broken down into 2 separate AXI transactions: a 16-beat, burst transaction and a single-beat, non-burst transaction. WLAST is asserted to signify the last beat/transfer of each of those transactions.
Note that WLAST is not valid unless an AXI "transfer" is occurring--which, by definition, is "only when both the VALID and READY signals are HIGH". The WLAST signal value is a don't-care when a transfer is not taking place. In this instance, the DMA IP knows that it has de-asserted WVALID at the end of the 16-beat burst, so it's free to do whatever it wants with WLAST--like leaving it high. When the next transfer starts (for the single-beat transaction), WLAST becomes/is-already valid.
Not unnecessarily de-asserting WLAST between the two transactions is the most efficient way to handle this situation.
-Joe G.
jg_bds
-Joe G.
giacomo87vett
Thank you, now it is clear for me.
Giacomo V.
