aimgmbh
AXI interconnect with 3 axi master burst slaves to 1 master hp port
I have followed constellation using the newest VIVADO 2014.1 release:
3 AXI Master Burst V2.0 Cores that are connected to 3 AXI-slave ports on an axi-interconnect (1.7). The AXI-master port from the interconnect goes to the AXI High performance port on the zynq system.
With that constellation i can write or read from 3 different interfaces over the high-performance-port to the zynq-ddr-memory.
With 2 instead of 3 AXI Master Burst cores (2 Slaves on the axi-interconnect , 1 master) it works fine.
All the time when i add the 3. slave port with my axi-master-burst-logic i realize in chipscope that i become no complition-complete(IPIF acknowledge signal) and the axi bus becomes no response (bready signal hangs).
Is it a problem with the AXI ID signals ? The axi master burst core offers no AXI ID signals and i connect the Slave IDs (AWID, ARID) to 0. I test it also with different values.
What do i must consider if i connect on axi-interconnect 3 or more slaves to 1 master ?
I hope somebody can help me.
aimgmbh
Any known issues about connection more than 1 Xilinx IP Core "AXI-Master-Burst" over "AXI-Interconnect" to HP-Port ?
mdr
I'm actually experiencing a similar problem. I have an AXI Interconnect with 3 masters. One master is a DMA core (NW Logic DMA Back-End), and two are AXI Datamover blocks. The slave interface on the Interconnect goes to a MIG7.
When I attach only two slaves interfaces, they seem to work fine. Once I add the 3rd master, the interconnect becomes a brick, and nothing gets through. Is this simply a bug in the core design itself?
aimgmbh
I solved my problem by connecting my last "AXI-Master-Burst" instead of slave-port 3 on the axi-interconnect to slave-port 1 (and the MAster-Burst which was on slave-port to slave-port3). Until i change this all axi-interconnect members work fine.
I dont understand why because the AXI connections are for sure the same (check that in detail).
Maybe you can fix your problem in the same way.
mdr
So all you did was swap the connections to slave ports 1 and 3? No other changes?
Do all of your AXI-Master-Burst ports have the same width?
aimgmbh
Yes. I think it was by me a timing problem. You should check your clocks on the different ports. If you have different clocks you should enable register slice and clock synchronisation.
aimgmbh
My ports have all the same width. The only explanation for me is by changing the ports you will have a different timing.
