02-19-2019 12:44 PM
I have two inputs, one output using AXI4-Stream Interconnect as a mux. In order to get maximum throughput, I can't survive frequent throttling tready. Tried maximum FIFO Depth (=4096) on all ports, with packet mode or not.
Data Flow Properties:
Arbitrate on TLAST transfer = Yes
Arbitrate on maximum number of transfers = 1024
Arbitrate on number of LOW TVALID cycles = 0
Arbiter Algorithm = True Round-Robin
But ILA capture shows, slave port tready start throttling after 60-something clocks, when there is only one input is active, the other is absolutely idling.
Please share your thoughts,
02-19-2019 03:01 PM
The AXI-S Interconnect is an intermediary. It can only take data in, as fast as it can send data out.
Throttling happens when data is arriving faster than it can be handled.
I recommend you check-out the Throughput section of the IP's PG:
-Joe G.
02-19-2019 03:19 PM - edited 02-19-2019 03:23 PM
I am presuming that, at this point, you've already verified that the TREADY into the downstream master port of the AXI-S Interconnect is ALWAYS high, so the problem MUST be within this IP...
-Joe G.
02-19-2019 06:00 PM
Thanks for pointing out PG035, I was not aware of throughput consideration at all.
But even with the example shown in PG035. It doesn't list a throughput limit. My case is 64-bit @ 156.25MHz, it's way under the example's throughput. What am I missing?
02-19-2019 06:10 PM
You missed the point.
You need to determine the throughput of your output interface (from the AXIS Interconnect) and the throughput of the switch inside the Interconnect. If either of those is less than the throughput of the input interface, the input interface will back-up.
-Joe G.
P.S. And just to be sure: the TREADY input of the output interface is always high, right?
02-19-2019 06:18 PM
Thanks for your help, I'm certain the output interface m_axis tready is alwasy high.
I have two inputs one output all at the same size and clock, basically it's a mux.
02-23-2019 09:59 AM
I don't understand this cause yet, will try coding up my own mux.
02-25-2019 04:19 PM
Hi @legendbb,
If you have a trace of the inputs and outputs of the AXI4-Stream Interconnect, that would be a big help. This might be a matter of refining the arbiter configuration.
It's not clear to me when you say that TREADY throttles, which side of the interconnect you are referring to.
Deanna
07-15-2019 08:32 AM
Hi all,
Sorry to open up the old thread, but I had found no solution to my issue yet.
Please see attached for what I meant for tready throttling.
2 inputs: S0 and S1; 1 output: M0
When there is no activity at all on S1, following things don't look right:
1. S0 axis.tready signal throttling.
2. M0 axis.tvalid not continuous.
All 3 ports are clocked with the same clock (156.25MHz) same TDATA width, I can't found throughput info from PG085 in the format of PG035. I'm not sure if the concept Switch clock (PG035 chapter Throughput) does exist in this version of IP or not.
Please comment,
07-16-2019 07:46 AM
Hi @legendbb ,
Could you add a screen shot of the configuration GUI for the AXI Stream Interconnect? I am interested in seeing the arbiter configuration. To me, it looks like you are arbitrating on every transfer rather than on TLAST.
Deanna
07-16-2019 07:57 AM - edited 07-16-2019 08:22 AM
Hi Demarco,
Thanks for looking into this. You are right, my packet size increased since original post. Now it's longer than 1024-Transfers. "Arbitrate on maximum number of transfers" maximum value is 1024, I had to set to 0, so my packet won't break. PG085 says: "If set to zero, then the number is infinite and Arbitrate on TLASt transfer must be set"
I just realized, S1.TLAST (output of AXI DMA through AXI4-Stream Data FIFO) is stuck high after a packet is sent. Maybe this is why.
Please see my configuration:
07-16-2019 04:34 PM
Hi @legendbb ,
S1.TLAST staying high after a transfer has completed doesn't matter as long as TVALID is unasserted.
Could you try using the Round Robin algorithm rather than the Fixed-Priority algorithm?
Do you still have FIFOs on the SI of your design? How deep are they? Is packet mode enabled or disabled?
Deanna
07-16-2019 04:37 PM
Hi Demarco,
Thanks for your update, I've tested changing TLAST to be single pulse with TVALID. And you are right, it doesn't matter.
I will try Round Robin tomorrow, although it changes the function I want.
AXIS data fifo is 4096 deep in non-packet mode.
07-17-2019 08:27 AM
Just to update, tested "Round Robin" same thing.
07-24-2019 08:45 AM
Another update: I tired simulating the AXI4-Stream Interconnect with AXI4-Stream VIPs as the data sources and sinks. I am not able to re-create the behavior in this case in simulation. I'm not sure what to attribute the throttling to.
07-24-2019 12:21 PM
Great thanks to your effort, this issue is actually in my back burner and I've been working on something else recently.
I will try your project soon.
