Brave
About multi boot after restart
I need the user to switch the bootloader, but after setting the multi_boot , uboot reset or file system reboot, the multi_boot is cleared.Is there any way?
Tags (4)
abhinayp
Hi @Brave
The CSU multiboot register is cleared only when the powered off or Power on Reset is used, if you are not using them and still the issue is with either WDT reset or soft reset then let me know.
How are issuing the reset? I mean the procedure if it a part of code.
Please read Reset_reason_register and check which reset was issued.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
