workingonit
Address range of a customised IP
If I want to create my own Vivado IP, customize it and connect it to the zynq processing system,
1) How can I deduce the address range (window) for that IP? suppose I'm using a zynq SoC,
2) What is the problem of using an address range of 1 ( 2 to the power zero), since it's just a window used by the processor to designate to which the incoming data is to be addressed?
stephenm
The address range depends on the number of address bits. So, you will likely have 32 bits. So 2 ^ 32 max.
However, if you connect this in IPI, the tools will handle the address range will be automated for you.
vanmierlo
Mentor
Mentor
If you use an address range of 1, then you effectively say: this IP has only a single address in use, so the AXI interconnect need not send me any address and I expect the AXI interconnect to enable me only when my address is used. i.e.: You leave the whole address decoding to the interconnect.
It's more efficient for the interconnect if  just claim a range of say 64k and to respond to any address by ignoring the address lines in your IP. It also leaves you the option to later implement more registers.
