Autogenetaion of pin constraints for the zynq design using Vivado
hi.,
i am designing custom board using zynq-7z045-900i.
i did my basic design in vivado HLS.
i have systhesis it.
can i able to generate the tool recommended pin constraints to my design.
this i want to do it and used the same pin assignments for my PCB design.
i didnt find anything about this auto generation of pins.
i m using ENET1 , SPI0,SPI1,IIC1 on EMIOs.
any guidelines much appriciated.......
thanks in advance.................
hi all.,
i came to know the auo placeing io ports.
after synthesis i went io pin planning(defalut layout). selected auto io pin placing of each interface .
BK.,
hi all.,
BK.,
