hwfgjdsd
C_PLBV46_NUM_SLAVES has value 17 which does not fall in the range (1:16)
I am using 17 slaves on my PLB-bus. So I modified the parameter C_PLBV46_NUM_SLAVES in the file “plb_v46_v2_1_0.mpd”. As like found in this thread:
http://forums.xilinx.com/xlnx/board/message?board.id=EDK&message.id=5619
Generating the bitfile is working fine now. But I need my MicroBlaze-project in a separated output-file to include it with other VHDL-parts to the FPGA. When I start generating design reports in XPS (Project -> Generate and View Design Reports), the XPS will finish with this error message:
Performing System level DRCs on properties...
ERROR:MDT - C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\plb_v46_v1_03_a\data\plb_v46_v2_1_0.mpd line 35 - PARAMETER C_PLBV46_NUM_SLAVES has value 17 which does not fall in the range (1:16), specified in MPD
Running DRC Tcl procedures for OPTION SYSLEVEL_DRC_PROC…
FATAL_ERROR: GuiUtilities: Gq_Application.c:590:1.20 - This application has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, …
ebCase with this project attached at http://www.xilinx.com/support.
Do anyone  know why I get this error message please?
Message Edited by hwfgjdsd on 09-24-2009 06:04 AM
