vivienwwp
C-code and disassembly file not matching
   I've got my C-code and the Microblaze doesn't seem to run to main(). I can step through the code from location 0x0 but it doesn't look like my c-code is at 0x0. How do I find out where the C-code resides on BRAM? FYI, I do not have a DDR on board. I would assume code would be at 0x0 but it doesn't look like it.
   The elf file generated shows that main code starts from 0x9c0 but the disassembly which I am stepping through doesn't match up with the elf file. Now I am not sure if the code is loaded correctly onto bram.
Thanks!
