Can I use LWIP echo server with SDK 2017.4
Hi, I use the zc702 and want to use the LWIP echo server project with SDK 2017.4, Ubuntu 16.04, but FreeRTOS doesn't have suitable version, the latest is 2016.3, and I got errors when I use it, How can I use this example project correctly. Any suggestion could be help.
Re: Can I use LWIP echo server with SDK 2017.4
Hi @reading_echo
Please check with this thread.
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-2016-4-FreeRTOS-LwIP-BSP-sample-echo-application-not/td-p/747045
Best Regards,
Srikanth
Thanks for this information, but it doesn't work. I cannot find the right version of FreeRTOS and lwIP demo , my SDK is 2017.4...
