Hi there. I'm trying to make a simple loopback test for Ethernet PHY (Marvell 88E1111) at 1000 Mbps speed on Microblaze system for Spartan 6 xc6slx150t-3fgg676 target device. I connected axi_ethernet and axi_dma ip-cores and created a peripheral test in Xilinx SDK. The generated project contains, among others, a testperiph.c file, where there is no code for testing axi_ethernet core, only a comment "AxiEthernetPolledExample does not support AXI DMA".
As I think I need to modify example source code to make the application work with axi_dma ip-core. What is the start point? Is the some example or project with such case?
