Mentor
Mentor
Can't initialize FPGA from SDK
Hi all,
I have a custom board with a SP6 and DDR-II as well as other ordinary peripherals - UART, LED,..- I made a project in EDK with SP6 DDR2, UART and LEDs and exported it to SDK. When I try to program FPGA , I receive below errors:
ERROR:Data2MEM:80 - ADDRESS_SPACE or ADDRESS MAP tag name 'ub' was not found. Some data may have not been translated.
FPGA Programming Failed due to errors while initializing bitstream.
I had just renamed "microblaze" to "uB" in EDK to make names shorter. What is the problem?
I appreciate any comment.
Hossein
Hossein
Did you get a chance to look at this AR? http://www.xilinx.com/support/answers/51180.html
--Hem
