dimpy
Coding SPI_PS using SPI driver in Xilinx SDK
Hello @sabankocal
I am new to SPI and would like to know who to proceed for it. For a start here is what i have dome.
I have generate the bitstream for same and export it to the Xilinx SDK.
FPGA is working as Slave device.
In the SDK i have created the hello world application project. I took reference from the xspips_slave_polled_example . Please find the below code.
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h" /* SDK generated parameters */
#include "xspips.h" /* SPI device driver */
/************************** Constant Definitions *****************************/
* The following constant map to the XPAR parameters created in the
* xparameters.h file. They are defined here such that a user can easily
* change all the needed parameters in one place.
#define SPI_DEVICE_ID XPAR_XSPIPS_0_DEVICE_ID
* The following constant specify the max amount of data the slave is
* expecting to receive from the master.
#define MAX_DATA 100
/**************************** Type Definitions *******************************/
/***************** Macros (Inline Functions) Definitions *********************/
#define SpiPs_RecvByte(BaseAddress) \
(u8)XSpiPs_In32((BaseAddress) + XSPIPS_RXD_OFFSET)
#define SpiPs_SendByte(BaseAddress, Data) \
XSpiPs_Out32((BaseAddress) + XSPIPS_TXD_OFFSET, (Data))
/************************** Function Prototypes ******************************/
void SpiSlaveRead(int ByteCount);
void SpiSlaveWrite(u8 *Sendbuffer, int ByteCount);
int SpiPsSlavePolledExample(u16 SpiDeviceId);
/************************** Variable Definitions *****************************/
* The instances to support the device drivers are global such that they
* are initialized to zero each time the program runs. They could be local
* but should at least be static so they are zeroed.
static XSpiPs SpiInstance;
* The ReadBuffer is used to read to the data which it received from the SPI
* Bus which master has sent.
u8 ReadBuffer[MAX_DATA];
* Main function to call the SPI Slave Example.
* @param None
* @return
* - XST_SUCCESS if successful
* - XST_FAILURE if not successful
* @note None
int main(void)
init_platform();
int Status;
xil_printf("Running SpiPS Slave Polled Example \r\n");
* Run the SpiPs Slave Polled example.
Status = SpiPsSlavePolledExample(SPI_DEVICE_ID);
if (Status != XST_SUCCESS) {
xil_printf("SpiPs Slave Polled Example Failed \r\n");
return XST_FAILURE;
xil_printf("Successfully ran SpiPs Slave Polled Example \r\n");
cleanup_platform();
return XST_SUCCESS;
* The purpose of this function is to illustrate how to use the XSpiPs
* device driver in Slave mode. This function reads data from a SPI Master
* and will echo it back to the Master.
* @param SpiDeviceId is the Instance Id of SPI in the system.
* @return
* @note None
init_platform();
int Status;
u8 *BufferPtr;
XSpiPs_Config *SpiConfig;
* Initialize the SPI driver so that it's ready to use
SpiConfig = XSpiPs_LookupConfig(SpiDeviceId);
if (NULL == SpiConfig) {
return XST_FAILURE;
Status = XSpiPs_CfgInitialize((&SpiInstance), SpiConfig,
SpiConfig->BaseAddress);
return XST_FAILURE;
* The SPI device is a slave by default and the clock phase
* have to be set according to its master. In this example, CPOL is set
* to quiescent high and CPHA is set to 1.
Status = XSpiPs_SetOptions((&SpiInstance), (XSPIPS_CR_CPHA_MASK) | \
(XSPIPS_CR_CPOL_MASK));
return XST_FAILURE;
memset(ReadBuffer, 0x00, sizeof(ReadBuffer));
* Set the Rx FIFO Threshold to the Max Data
XSpiPs_SetRXWatermark((&SpiInstance),MAX_DATA);
* Enable the device.
XSpiPs_Enable((&SpiInstance));
* Read the contents of the Receive buffer
* Master is expected to send MAX_DATA number of bytes
SpiSlaveRead(MAX_DATA);
* Setup a pointer to the start of the data that was read into the read
* buffer and the same back
BufferPtr = ReadBuffer;
* Send the data received back to Master
* Master is expected to send MAX_DATA number of dummy bytes for
* the slave to be able to echo previously received data.
SpiSlaveWrite(BufferPtr, MAX_DATA);
* Disable the device.
XSpiPs_Disable((&SpiInstance));
return XST_SUCCESS;
* This function reads from the Rx buffer
* @param ByteCount is the number of bytes to be read from Rx buffer.
* @return None.
* @note None.
int Count;
u32 StatusReg;
StatusReg = XSpiPs_ReadReg(SpiInstance.Config.BaseAddress,
XSPIPS_SR_OFFSET);
* Polling the Rx Buffer for Data
do{
XSPIPS_SR_OFFSET);
}while(!(StatusReg & XSPIPS_IXR_RXNEMPTY_MASK));
* Reading the Rx Buffer
for(Count = 0; Count < ByteCount; Count++){
ReadBuffer[Count] = SpiPs_RecvByte(
SpiInstance.Config.BaseAddress);
* This function writes Data into the Tx buffer
* @param Sendbuffer is the buffer whose data is to be sent onto the
* Tx FIFO.
* @return None.
* @note None.
u32 StatusReg;
int TransCount = 0;
XSPIPS_SR_OFFSET);
* Fill the TXFIFO with as many bytes as it will take (or as
* many as we have to send).
while ((ByteCount > 0) &&
(TransCount < XSPIPS_FIFO_DEPTH)) {
SpiPs_SendByte(SpiInstance.Config.BaseAddress,
*Sendbuffer);
Sendbuffer++;
++TransCount;
ByteCount--;
* Wait for the transfer to finish by polling Tx fifo status.
do {
XSPIPS_SR_OFFSET);
} while ((StatusReg & XSPIPS_IXR_TXOW_MASK) == 0);
After doing this, programmed the FPGA and run the configuration. But i am not getting any output on the console. Kindly help me to solve this.
Thank you.
abommera
Hi @dimpy,
If you are not seeing anything on UART, please double-check the baud rate. Try to do "Debug as" your application project and check whether the breakpoint hitting at print function (xil_printf("Running SpiPS Slave Polled Example \r\n");) or not.
Thanks & Regards
Anil B
dimpy
Hello @abommera
Please find the attached Screenshot of my console where i am only getting "Running SpiPS Slave Polled Example ".
After it i am not getting anything. Also i am not getting any clk.
Please find the attached zip file of my design and help me to getting spi clk.
Thank you.
