Communication between two ARM cores in Zedboard using shared memory
Hai everyone,
i want to  send data from one ARM core in zedboard to another ARM core in the same. I understood that for this shared memory can be used. but i cant able to understand how to use, can anyone kindly help me regarding this??
thanks in advance
XAPP1079 describes baremetal on CPU0 talking to baremetal on CPU1 over shared memory.
http://www.wiki.xilinx.com/XAPP1079+Latest+Information
UG1186 describes linux on CPU0 talking to baremetal on CPU1 also over shared memory, but via remoteproc/rpmsg drivers.  It's a lot more complicated.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1186-zynq-openamp-gsg.pdf
check these links
http://xillybus.com/tutorials/device-tree-zynq-1
http://zedboard.org/content/how-communicate-ddr-memory-locations-zedboard
http://zedboard.org/content/shared-memory-openamp-configuration
Thanks and Regards
Balkrishan
