francocapraro12
Configure a S_AXI_CTRL in PL
Hello. I want to know if is possible (and how) configure the S_AXI_CTRL axi's, for example a Test Pattern Generator has an S_AXI_CTRL. Normally the config is a task for the PS part, but i want to configure it in the PL part through a verilog module.
Best,
FC
Tags (2)
florentw
Hi @francocapraro12
Yes this is possible. This is only AXI4 transactions. So you just have to send AXI write transactions to configure the TPG.
Florent
florentw
Hi @francocapraro12
Florent
francocapraro12
Thank you so much. About the data to send with AXI write transactions , i can see it in the IP Cores documentations ?
Best,
FC
florentw
Hi @francocapraro12
Yes this is in the documentation for the TPG. For example if you want to start the TPG and keep it running, write 0x81 to the address 0x0000:
Florent
francocapraro12
Hi @florentw . I want to know if you have/know about some example in HLS to do AXI write transactions. I think this can reduce the effort to obtain the transactions.
Best,
FC
florentw
HI @francocapraro12
There are probably some examples. You might want to ask on a new topic on the HLS board you will probably get an answer
Florent
