DAC interface
I have gone through one document.In which an video signal is converted into AXI stream and after processing from DDR3 memory it is displayed on HD monitor.
So if suppose i want PAL format to dispaly on monitor can i connect DAC??If i will use DAC 7123 will this support?How this DAC can be interfaced and where??
I am sorry for asking so many questions as i want to learn it thoroughly from in and out in all possible ways.
Thank you
With regards
Pallavi
HI Pallavi
The video format in the XAPP is different. I think you wouuld need a decoder for the conversion of two formats.
The earlier thread was an just an example to show a similar system implementation.
Hope thats helpful to you.
Sikta
Could you please guide me about above question?as i have gone through the document which you have given but it hasnt cleared my requirement.
I have attached an document from where i got this doubt.
In one of document which you had given me there is a discussion about DAC , in that a person is using separate video decoder chip only and i want to know whether at the ouput side can i connect DAC 7123 to display PAL format instead of HD format which the attached document say.
Thank you
Thank you
With regards
Pallavi
HI Pallavi
Sikta
