inass
DDR2 error
ERROR:Place:713 - IOB component "fpga_0_DDR2_SDRAM_DDR2_DQ_pin<13>" and IODELAY
   component
   "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g
   en_dq[13].u_iob_dq/u_idelay_dq" must be placed adjacent to each other into
   the same I/O tile in order to route net
   en_dq[13].u_iob_dq/dq_in". The following issue has been detected:
   Some of the logic associated with this structure is locked. This should cause
   the rest of the logic to be locked.A problem was found at site IODELAY_X0Y56
   where we must place IODELAY
   DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/ge
   n_dq[13].u_iob_dq/u_idelay_dq in order to satisfy the relative placement
   requirements of this logic.  IODELAY
   n_dqs[0].u_iob_dqs/u_iodelay_dq_ce appears to already be placed there which
   makes this design unplaceable.
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
I'm using xupv5-lx110t to make a simple desing contening MB, timer, and DDR2_SDRAM.
But when I want to generate the bitstream an error arise:
ERROR:Place:713 - IOB component "fpga_0_DDR2_SDRAM_DDR2_DQ_pin<13>" and IODELAY   component   "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g   en_dq[13].u_iob_dq/u_idelay_dq" must be placed adjacent to each other into   the same I/O tile in order to route net   "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g   en_dq[13].u_iob_dq/dq_in". The following issue has been detected:    Some of the logic associated with this structure is locked. This should cause   the rest of the logic to be locked.A problem was found at site IODELAY_X0Y56   where we must place IODELAY   DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/ge   n_dq[13].u_iob_dq/u_idelay_dq in order to satisfy the relative placement   requirements of this logic.  IODELAY   DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/ge   n_dqs[0].u_iob_dqs/u_iodelay_dq_ce appears to already be placed there which   makes this design unplaceable.  ERROR:Xflow - Program map returned error code 2. Aborting flow execution... make: *** [__xps/system_routed] Error 1
Please if any one has some useful ideas please tell me.
Thx in advance;
INASS,
robinliuy
Voyager
Voyager
Is your DDR2 core generated by MIG? Did you change anything outputed by MIG? I'm afraid there is location confliction for IODELAY.
ben_hlima_ines
I just compiled a project from a tutorial xupv5-lx110t_bsb_design that containe the pinaout of the DDR2!!
nlw
bump
same problem...does anyone have a solution?
This also doesn't work with the mpmc from the Base System Builder wizard
dylan
The likely cause is that the MIG UCF constraints were not created or adapted for that pinout.
nlw
What would the proper solution be?  Would it be easier to downgrade to 11.5?
Or if i want to remove the core and regenerate the MIG, how would I do that?  Do I have to go to the ise?
