Devicetree Generator issue
I'm using Vivado 2014.4 and the Xilinx Devicetree Generator from Github and since a few days I have the problem that the ethernet part in the ps.dtsi file got reset to this default value
		ps7_ethernet_0: ps7-ethernet@e000b000 {
			#address-cells = <1>;
			#size-cells = <0>;
			clock-names = "ref_clk", "aper_clk";
			clocks = <&clkc 13>, <&clkc 30>;
			compatible = "xlnx,ps7-ethernet-1.00.a";
			interrupt-parent = <&ps7_scugic_0>;
			interrupts = <0 22 4>;
			local-mac-address = [00 0a 35 00 00 00];
			phy-mode = "gmii";
			reg = <0xe000b000 0x1000>;
			xlnx,ptp-enet-clock = <0x6750918>;
			xlnx,enet-reset = "";
			xlnx,eth-mode = <0x0>;
			xlnx,has-mdio = <0x1>;
			mdio {
				#size-cells = <0>;
every time when I open the Xilinx SDK.
But i need a Phy entry to get my ethernet working:
			#size-cells = <0>;
			phy-handle = <&phy0>;
			phy-mode = "rgmii-id";
			xlnx,eth-mode = <0x1>;
		mdio {
			#size-cells = <0>;
			phy0: phy@1 {
				compatible = "realtek,RTL8211E";
				device_type = "ethernet-phy";
				reg = <1>;
 What is the reason for that problem?
Thanks for help...
the ONLY file you can touch is
system.dts
if you make changes to any other file they will get lost of course.
so please use system.dts as you are supposed to, and do not try to modify any other files. then it all works.
system.dts
Thank you for your reply.
Can I add this part
			#size-cells = <0>;
		mdio {
			#size-cells = <0>;
			phy0: phy@1 {
				reg = <1>;
 into my system.dtsi, or should I only add the modifications of the ethernet part into that file?
