Anonymous
Not applicable
DisplayPort Reference Clock
In the DisplayPort Product Guide (v4.2), it states:
"For 7 series FPGAs, a common reference clock of 135 MHz (harmonic of 27 MHz) is needed for 1.62, 2.7 and 5.4 Gbps link
rates."
Does this apply to the Zynq? Just wanted to confirm since I believe that the Zynq PL fabric is oftern referred to as 7 Series equivalent fabric?
Hope you are referring Zynq PL only and not PS,  Yes, unless specified separately  the statement would apply to Zynq  as well and I believe those are from Spec as well so in general would be common across devices.
Hope thsi helps
Vanitha
Anonymous
Not applicable
Yes, I was only referring to the PL. Thanks for your input.
