komura.koji
Doesn't work UartLite with interupt
I'm programming with Microblaze(Spartan6).
I compiled correctly,but seem to not working.
When input a serial data,not call interrupt handler.
Attachment file is my source code.Is something wrong?
I use uartlite_v2_01_a and intc_v2_06_a libraly.
follow is xparameters.h
/* Canonical definitions for peripheral RS232_2 */
#define XPAR_UARTLITE_2_DEVICE_ID XPAR_RS232_2_DEVICE_ID
#define XPAR_UARTLITE_2_BASEADDR 0x40600000
#define XPAR_UARTLITE_2_HIGHADDR 0x4060FFFF
#define XPAR_UARTLITE_2_BAUDRATE 115200
#define XPAR_UARTLITE_2_USE_PARITY 0
#define XPAR_UARTLITE_2_ODD_PARITY 0
#define XPAR_UARTLITE_2_DATA_BITS 8
#define XPAR_UARTLITE_2_SIO_CHAN 1
/* Canonical definitions for peripheral AXI_INTC_0 */
#define XPAR_INTC_0_DEVICE_ID XPAR_AXI_INTC_0_DEVICE_ID
#define XPAR_INTC_0_BASEADDR 0x41200000
#define XPAR_INTC_0_HIGHADDR 0x4120FFFF
#define XPAR_INTC_0_KIND_OF_INTR 0xFFFFFFF9
#define XPAR_INTC_0_HAS_FAST 0
#define XPAR_INTC_0_IVAR_RESET_VALUE 0x00000010
#define XPAR_INTC_0_NUM_INTR_INPUTS 3
#define XPAR_INTC_0_INTC_TYPE 0
#define XPAR_INTC_0_UARTLITE_2_VEC_ID XPAR_AXI_INTC_0_RS232_2_INTERRUPT_INTR
#define XPAR_INTC_0_IIC_0_VEC_ID XPAR_AXI_INTC_0_AXI_IIC_0_IIC2INTC_IRPT_INTR
#define XPAR_INTC_0_TMRCTR_0_VEC_ID XPAR_AXI_INTC_0_AXI_TIMER_0_INTERRUPT_INTR
 Please help me!
komura.koji
Finally, I found a solution.
Xilinx staff saying,this is a bug of System Debugger(Xilinx SDK).
I used a System Debugger.But I change to GDB,it works good.
Try this:
int UartLiteSetupIntrSystem(XIntc *IntcInstancePtr,
				XUartLite *UartLiteInstPtr,
				u16 UartLiteIntrId)
	int Status;
	 * Connect a device driver handler that will be called when an interrupt
	 * for the device occurs, the device driver handler performs the specific
	 * interrupt processing for the device.
	Status = XIntc_Connect(IntcInstancePtr, UartLiteIntrId,
			(XInterruptHandler)XUartLite_InterruptHandler,
			(void *)UartLiteInstPtr);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * Enable the interrupt for the UartLite.
	XIntc_Enable(IntcInstancePtr, UartLiteIntrId);
	XUartLite_EnableInterrupt(UartLiteInstPtr);
	return XST_SUCCESS;
int IntcInterruptSetup(XIntc *IntcInstancePtr, u16 DeviceId)
	int Status;
	 * Initialize the interrupt controller driver so that it is
	 * ready to use.
	Status = XIntc_Initialize(IntcInstancePtr, DeviceId);
		return XST_FAILURE;
	 * Perform a self-test to ensure that the hardware was built  correctly.
	 * Initialize the exception table.
	Xil_ExceptionInit();
	 * Register the interrupt controller handler with the exception table.
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
			(Xil_ExceptionHandler)XIntc_DeviceInterruptHandler,
			(void*) 0);
	 * Enable exceptions.
	Xil_ExceptionEnable();
	 * Start the interrupt controller such that interrupts are enabled for
	 * all devices that cause interrupts.
	Status = XIntc_Start(IntcInstancePtr, XIN_REAL_MODE);
		return XST_FAILURE;
	return XST_SUCCESS;
main( )
{ if ( IntcInterruptSetup(&InterruptController, XPAR_INTC_0_DEVICE_ID)!= XST_SUCCESS ) return XST_FAILURE; if ( XUartLite_Initialize( &uartData, XPAR_UART_DATA_DEVICE_ID) != XST_SUCCESS ) return XST_FAILURE;
    if ( UartLiteSetupIntrSystem(&InterruptController,&uartData, XPAR_UART_DATA_INTERRUPT_INTR )!= XST_SUCCESS )
        return XST_FAILURE;
komura.koji
Thank you for your replying.
But, now my device doesn't work.Sended serial data is received UartLite IP.
So I can receive all data with polling procedure.But with Interrupt doesn't.
My way for confirmation is that set a breakpoint to a function XIntc_DeviceInterruptHandler().
But doesn't break to this point...
htsvn
hi,
can you attach the code that you are trying?
--hem
komura.koji
Thanks,replying.
I have attached my code...
Please refer all this post.
komura.koji
