Dual MicroBlaze lockstep,microblaze 0 runing but microblaze 1 do not runing
I want to bulid a small system to test the Microblzae lockstep interface, and my systhem is show in the base_mb.pdf.
When I just to down load the .elf into the MicroBlaze core use SDK,  I found that only microblaze 0 is runing.
So why the microblaze 1 dosen' t working?
Please help.
Re: Dual MicroBlaze lockstep,microblaze 0 runing but microblaze 1 do not runing
If arranged as dual core lockstep,
Then it is one processor, not two.  As they execute the same instruction at the same time, there is no 'view' of the second processor.  It is one processing element, executing one program.
l.e.o.
l.e.o.
but why my TMR comparator output is always high,  is that mean the dual processor unloacked?
TMR?
Duplicated is 2, not three.  Acting as one.  Triplicated is 3.  Still acting as one.  So which did you specify, duplicated, or triplicated?  In any case, it acts as one processor.
l.e.o.
Thanks, I found that the reserved ports of lockstep output couse comparator outputs high.
