GPIO core : should i use plb_gpio or xps_gpio ?
The EDK (11.2) has 2 cores that provide PLB access to a GPIO function.
C:\Xilinx\11.1\EDK\hw\XilinxProcessorIPLib\pcores\plb_gpio_v1_00_b
C:\Xilinx\11.1\EDK\hw\XilinxProcessorIPLib\pcores\xps_gpio_v2_00_a
If i use the XPS GUI to build a processor sub - system, it seems to use the xps_gpio.
Which is the recommended to use.
Both seem to give similar/same functionality.
Derek
Historian
Historian
Re: GPIO core : should i use plb_gpio or xps_gpio ?
derekwallace1 wrote:
Derek
Use neither. It's simple enough to build your own "IP Core" to satisfy your particular requirements.
Hi Derek,
It depends on which processor you are using. PLB peripheral has a PLB v3.2 bus, while XPS peripheral has a PLB v4.6 bus.
If you are using the latest vesion of processor (Microblaze or PowerPC), XPS peripherals should be used.
-XF
