How can I generate TX signal using CANFD core IP?
Hi everyone!
I try to set the custom IP with CANFD interface using the ZC706.
I composed CANFD interface system with zynq process.
After generate bit file and tried to control at the SDK.
I program the CANFD IP control code to generate TX message, But it didn't work.
When I checked using oscilloscope, I couldn't find any signal.
Is there anybody know about the sequence to generate TX signal?
For example, I generate C code like as below.
set ID,
set DLC,
CANFD enable
write data at TX buffer,
Re: How can I generate TX signal using CANFD core IP?
Hi @kyrini,
Did you try using CANFD example template in SDK?
Regard
Praveen
