05-06-2019 01:04 AM
Can anyone please give some ideas for Accessing my PS ethernet,
I have a custom board having ZYNQ 7000 SOC (XC7Z045ffg900-2) with ethernet, UART , and QSPI alone connected in PS side and DDR connected in PL side
I am new to SOC design, I tried to use emacps example design but it uses ps DDR, Is there any possibility to use my PS ethernet without using PS DDR, give some ideas.
Thanks in advance
Vignesh,C
05-06-2019 01:18 AM
You should read the Zynq Book.
Free dwnld after regd: http://www.zynqbook.com/download-book.php
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
05-06-2019 11:57 PM
I had gonethrough The Zynq book but couldn't got any reference for accessing ethernet without using DDR
Without using DDR is it possible to use PS ethernet?, Kindly provide any example as soon as possible
Thanks in advance
Vignesh.C
05-07-2019 01:36 AM - edited 05-07-2019 01:51 AM
In one night the complete book? You are surprisingly fast!
That book does not have an READY-MADE example design. I referred it to clear your fundamentals on the Zynq sub-system. Without understanding, clearing the fundamentals, it makes little sense to copy a design and implement it.
Wait...first -- what are you referring to by DDR? DDR* External memory?
Note- If you don't tag me, I may never read your post again.
