3008202060
How to add PL bitstream to linux application project
Hi all,
In my old design, I built several IP core, and added them to a top project that could be controlled by the ZYNQ processing system.(which is run on standalone).
Now, I want to run the code on linux system while still to use the IP core as hardware accelerator. I was wondering how should I do this.
I already get petalinux working and could generate the BOOT.bin/ devicetree.dtb/uImage/uramdisk.image.gz files. I could use these file to boot the board from sd card.
However, when I try to generate the BOOT.BIN file using fsbl.elf/bitstream.bit/u-boot.elf, and put the new BOOT.BIN to the sd card. It didn't work.
Could any one tell me where I was wrong? Thanks a lot.
Am I need to write linux device driver for those hardware accelerator?
----------------------detail action--------------------
1.start Vivado software.
2. New Project.
3. Select zedboard from Board lists.
4. Create Block Design.
5. Add Ip
6. Add Zynq7 Processing System.
7. Run Block Automation
8. Route M_AXI_GP0_ACLK pin to FCLK_CLK0 pin.
9. Validate Design (no error).
10. create wrapper
11. Generate Bit stream
12. open petalinux
13. create and build one test project(generated all the boot.bin/uimage..)
14. Open sdk
15. create boot image : add design_1_wrapper.bit as data file, add fsbl.elf/u-boot.elf generated from petalinux project
16.copy the BOOT.bin to sd card.
17. power on.
18. connect the board through the terminal : sudo minicom -D /dev/ttyACM0 -b 115200 -8 -o
(this is how to usually connect the board, it works fine when I just other BOOT.BIN)
19. Nothing happened
fincs
I might not quite understand the question, but you can do this:
11.1 File => Export => hardware (include bitstream) => the result is .hdf file
12. open petalinux
13. petalinux-create --type project --template zynq --name test_ip_project
14. petalinux-config--get-hw-description=<PATH-TO-HDF-DIRECTORY>
UG1144 => Create a New PetaLinux Project
fincs
12. open petalinux
3008202060
Thanks for your reply. It did work. Again Thanks a lot.
