aiannuzzi
How to import .ELF files in a RTL design ?
I have an RTL design, using with a MicroBlaze. I need to import this design in a RTL hierarchy (.sv), porting also the .ELF files, related to uBlaze.
I found several flow info suggestions, such like AR# 67083 (https://www.xilinx.com/support/answers/67083.html) , but indicating how to import in a new BD design.
My case is diferent: how to import in a RTL hierarchy design. In my case, the BD is a top level, and the uBlaze is instanciated deep in the hierarchy. So I cannot import in the top bd.
If I import directly in the my top the .ELF files, Vivado cannot relate it to any uBlaze reference.
Any suggestions, please ?
Many thanks,
  Alex
aiannuzzi
I tried a similar command in Vivado:
wirte_bd_tcl command, to export the bd from the first design, generating a script.
In the second hierarchical design, I source this script, so I can create the bd in the new hierarchy..
  Alex
madhu.mami60
Hi @aiannuzzi
Have you tried by File-> Write Project Tcl option in Vivado?
Thannks
Madhu
aiannuzzi
  Alex
