jagruti
How to use UART 0 along with UART 1?
In my Zynq SDK program I am using user inputs as commands for operation. These user inputs are taken from UART. I also need to print program status on terminal. Both of these task goes parallel way. So, can I use UART 0 also. currently I am using UART 1 only. How  to do physical connection happens and what setting should be done in VIVADO if I plan to use UART 0 along with UART 1.
muzaffer
Why do you think you need two uarts? uarts are full-duplex ie they have both receive & transmit pins and you can do both at the same time.
In case you actually do, just connect uart0 & uart1 to different MIO pins. You do realize that this will require a hardware change and not just Vivado configuration (if the connection is not already on your board that is)
muzaffer
jagruti
Thanks!
Yes, UART is full duplex but, I am using terminal to display my System status and to take user commands from UART also. So the problem was sharing of Terminal. Now it is solved anyway!
Thanks for reply
ajcurtis84
Where you able to use both UARTs? Would you mind sharing how you solved this problem?
daniel_shieh
Hi, there.
I used uart1 as a system console before. But I also need to use uart0 as a serial to commnicate with another board. The hardware(board connection) is fine.
The problem is that when I enable uart0 along with uart1, uboot can's printk anything on the screen. How should I do to enable two uarts at the same time. U-boot configuration is to use uart1 an a console. So I do not know where should I change in this situation. Could you give me some ideas? Thanks.
Daniel Shieh.
