harish-anil
ILA Trigger from user-space application - petalinux
Hello Experts,
I have a custom logic which is hooked with a slave port sw_in and Master port System memory. I want to use ILA to capture system memory transactions and sw_in as the trigger, sw_in is feed with a certain value from the userspace app running on the CPU, so how do I achieve the below settings? any specific tutorial on how this works and how to interface ILA with userspace application. Looking for a sample design or example.
Below is the capture of my design where System ILA is instantiated as IP Block.
