ronnywebers
Advisor
Advisor
IP_Flow 19-3158 - FREQ_HZ bus parameter missing from AXI interface when interface is not associated to a clock
I've created and packaged a custom IP which has 2 master and 2 slave axis ports. To save on clock pins in the IP symbol, in my VHDL source, I've shared the axis_aclk and axis_aresetn signals for the 4 interfaces.
* I get a warning for each of the 4 axis ports, saying i.e. for the s00_axis interface:
[IP_Flow 19-3158] Bus Interface 's00_axis': FREQ_HZ bus parameter missing from AXI interface when interface is not associated to a clock.
* to create the axis interfaces from the signal, I had to select the signals (i.e. s00_axis_tdata, s00_axis_tlast, s00_axis_tvalid and s00_axis_tready), then right click 'auto-infer interface' -> select axis. Here's the result :
Q1 : I would expect that these interfaces are inferred automatically by the IP packager (?) Or is not possible for the tool because I shared the axis_aclk and axis_aresetn signal among the 4 ports?
From the warning I get, I think to understand that I have to tell IP packager which signal represents the axi clock, this is in my case axis_aclk. I guess this is needed for timing analysis?
Q2 : how can I do this?
-> i,e, if I right click on s00_axis I can select 'Associate clocks ...' this pops up the following dialog which only allows me to click ok, but nothing happens. I would expect I could select axis_aclk from a list?
-> I can also right-click, then select 'edit interface', and add the 'FREQ_HZ' parameter in the 3rd tab (parameters)
Q3: the warning disappears, but this seems very strange to me since I don't see how the signal axis_aclk is now associated with the s00_axis interface? I just added this parameter, but nothing about the axis_aclk signal
Q4 : what with the axis_aresetn signal? do I have to associate this in a similar way with a bus parameter?
gmarinkovic
Hello Ronny,
I just faced the same problem but fortunately the right click on s00_axis I can select 'Associate clocks ...'
In 2016.2 this looks like follows in my case:
Then the warning is gone. However I agree with you: Why can't the tool do this automatically... especially if only one clock is used.
Cheers
Goran
