IP upgrade error message
I get a target reference design "rdf0429-zcu102-es2-base-trd-2017-2" from Xilinx.
When I do Tcl command "upgrade_ip [get_ips *], it can't finish the operation.
The log file is as attached file, please help to check.
Hank
Hi @hankchen,
Please try to use Vivado from SDx 2017.2 (not the standalone vivado) to use the TRD. The TRD is targetting a specific version of vivado and is supported as this.
Florent
