Is it possible to get SOURCE CODE for petalinux-create and other utilities
Is it possible to get SOURCE CODE for petalinux-create and other utilities, I expected to find it in /petalinux-v2017.2-open_components but do not see it there.
Hi @beckett37,
No, the source code is not available to users.
Florent
Florent
Hi @beckett37,
Florent
Florent
