freynew
Is there any document about nand flash(yaffs2) on ZYNQ7000?
We want to implement Yaffs2 rootfs on Nand Flash, and we can not find any instruction about it.
Our demo board is MYiR Corp's Zynq -7010. There is no nand flash on the board. There is no related document about NAND Flash.
i think this requirement is very popular for embedded applications. Is there other xilinx demo board supporting it?
Or is there any document about is ?
balkris
check these documents
https://www.xilinx.com/Attachment/Nand_Flash_Support_Guide.pdf
https://www.xilinx.com/support/answers/50991.html
Thanks and Regards
Balkrishan
freynew
Thank you very much!
smarell
Community Manager
Community Manager
There is not much documentation. All I can find is this https://www.xilinx.com/support/answers/46285.html which clearly states that Jaffs2 is supported with NAND controller on Zynq. Let me see if I can find more information on implementing this.
