Issues with the AXI Interface on a Micoblaze Core
   I've got a design that includes a microblaze generated in Vivado 2013.3. I've exposed to the M_AXI_DP ports to my own logic. I'm noticing odd behavior that I've not seen in other AXI IP. Basically the AWADDRESS and AWVALID/WDATA and WVALID lines are a cycle apart. Why I can solve this by delaying WADDRESS/WVALID a cycle this makes me a tad nervous. Please let me know if you require more information.
Thanks for the help!
Too little information here. Can you post a screenshot of the signals ?
Are your trying to burst write to your logic?
I am using XPS and have a clock generator with multiple clock outputs and am trying to connect these to other peripherals, specifically a DMA module.  The 'help' screen for xps says
"To specify or change the port connectivity, select a new click inside the table cell and select a net from the list of compatible nets in your hardware platform (those having the same class and compatible polarity). "
I left click on the connection cell and nothing happens.  Right clicking gives me the option of No Connection, New Connection or Make External.  When I select New Connection, the window 'shakes', but nothing else happens.  It's as if there is a popup being blocked.  Note that this does work properly on another system.
Any ideas?  I'm using Windows 7.
David.
Belay that.  It's an artifact of using the extended desktop with two screens.
Unplugged the second screen and it worked.
Gotta love windows...
D.
@dwyskiel
Please don't hijack threads. Your posts have nothing to do with the original question. Make a new post when you have an issue.
