omar32s
Line 41: Signal regs[0][31] in unit REGFILE is connected to following multiple drivers
Hello here is my code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity REGFILE is
port
out1 : out std_logic_vector(31 downto 0);
out2 : out std_logic_vector(31 downto 0);
regselect1 : std_logic_vector(4 downto 0);               --select for out1
regselect2 : std_logic_vector(4 downto 0);               --select for out2
input : in std_logic_vector(31 downto 0);
WE : in STD_LOGIC;                                       --write enable
regselectw : in std_logic_vector(4 downto 0);            --reg. select for writing
reset : in std_logic;
clk : in std_logic
end REGFILE;
architecture reg_arch of REGFILE is
--t3ref ll registers
type regs_storage is array ( 0 to 31 ) of std_logic_vector(31 downto 0);
signal regs: regs_storage := (others => X"00000000");
begin
 --reset process-------------------------------------
 process (reset) is
 begin
 if reset='1' then
 regs(to_integer(unsigned(regselectw))) <= input;
 end if;
 end process;
 --input process--------------------------------------
 process (clk) is
 begin
 if rising_edge(clk) and WE='1' then
 end if;
 end process;
--output process--------------------------------------
 process (clk) is
 begin
 if rising_edge(clk) then
 out1 <= regs(to_integer(unsigned(regselect1)));
 out2 <= regs(to_integer(unsigned(regselect2)));
 end if;
 end process;
end reg_arch;
however I face the error Line 41: Signal regs[0][31] in unit REGFILE is connected to following multiple drivers
bruce_karaffa
You need to combine the reset process with the input process.  Try something like:
 process (clk) is
 begin
if reset='1' then
elsif WE='1' then regs(to_integer(unsigned(regselectw))) <= input; end if;
end if;
end process;
bruce_karaffa
 process (clk) is
 begin
if reset='1' then
end if;
end process;
