Looing for an DMA Example
Hello, I want to learn how to do a DMA from the PL-Side to the PS-Side. I am using the ZCU-106 board and am trying to develop a simple loop back test of the 64B/66B Aurura IP. I want to pass the data from the PS Side ARM processor to the PL Side Aurora IP. One option would be use a DMA IP in the PL side so I need to learn how this is done. If anyone knows of an example/tutorial where the PS ARM cores configures the DMA IP that would be very helpful. I am using the latest Vivado and Vitis tools.
Thank you,
Joe
Re: Looing for an DMA Example
Hi @joe306,
Please take a look on the AXI DMA Product Guide PG021.
You could find some example in the following Answer Record AR#57550.
Best regards,
Abdallah
Hi @joe306,
Best regards,
Abdallah
