vikaskanha
MICROBLAZE IN VIRTEX-7
Hello all,
I want to a create a microblaze design with AXI Timer interrupt, AXI Dma interrupt and GPIO Interrupt driven by virtex-7 FPGA core. Please help me with any availaible design or answer records.
stephenm
Can you mark this thread as solved, and open a new thread for this latest question please?
vikaskanha
Hello all,
I am eagerly waiting for your reply so that i can proceed. Please guide me.
Thanks & Regards
dpaul24
@vikaskanha,
Self-help is the best help!
Instead of waiting for others, why don't you search with the phrase - "getting started with microblaze"?
There are numerious tutorials available.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
vikaskanha
I followed the ug940 lab 3 and finished lab 3. Now i want to generate  interrupt at every 2 ms from timer that will read in microblaze. How this i have to do? Please guide.
stephenm
There is a example code or the drivers that you can use as a reference:
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/tmrctr/examples
vikaskanha
I am able to generate 2 ms interrupt. Now i want gpio interuppt. My target is when i will press push button it should print a message on terminal. Currently when pressing push button and releasing it both time it is pring on the terminal. I think it is configured for both rising and falling edge. How to configure it for rising edge only. I am following  the xgpio_intr_tapp_example.
stephenm
You can set the interrupt sensivity in the Interrupt controller:
By default this will be level edge. However, you can se this to be rising edge (Level=0, rising= 1):
for example, this capture the interupt on the rising edge on the gpio interrupt signal:
I used the VIO to stimulate a GPIO signal (If you are uisng a psuhbutton you might want to use debounce logic):
My code is seen above. In the handler, I print out the amout of interrupts that have occured:
Note: I also ack and clear the gpio interrupt
void InterruptHandler(void *CallbackRef)
 xil_printf("Interrupt Count: %u\r\n", count);
 XGpio_InterruptClear(&Gpio, 0x1);
 XIntc_Acknowledge(&Intc, XPAR_MICROBLAZE_0_AXI_INTC_AXI_GPIO_0_IP2INTC_IRPT_INTR);
 count++;
You should see the interrupts increment:
My code is attached
vikaskanha
Sir,
I have completely followed the sequence given in the  .c file and block design, but still i am getting the inrerrupt on both the edge.
Thanks & Regards
vikaskanha
I checked in ILA. Problem is not with the interrupt controller. Its AXI GPIO problem. Actually ip2intcirpt giving interrupt at both pressing and releasing time. How to configure AXI GPIO to give interrupt at rising edge only?
stephenm
This is the expected behaviour as mentioned i nthe AXI GPIO guide:
vikaskanha
Sir,
I want to pass only rising edge transition interrupt from gpio module  to interrupt  controller module. How Should i block the falling edge transition transition interrupt from gpio module to interrupt controller module.
Thanks & Regards
stephenm
When you added the ILA, Did you see two interrupts. One for press, one for release?
vikaskanha
Yes, In ILA i saw two interrupts. One For press and one for release. If you will not release second one will not come.
stephenm
Ok, then you can simply add a check in the interruot handler to read the DATA register in the GPIO to see if this is 0 or 1 and act accordingly:
 u32 data = Xil_In32(XPAR_AXI_GPIO_0_BASEADDR);
 if (data == 1) {
  count++;
In the code above, the interrupt counter will only increment if the first bit in the data register is high. In your case if there is a press
on the button.
vikaskanha
Sir,
Now i am able to get print at the time of button press. Thanks a lot for your valuable inputs and time. Meanwhile, with the reference of examples given with axi timer i  generated a 2 ms timer as a separate design. Now i want to stop and start my timer when there will be a button press. Basically there will be 2 sources of interrupts now. I want to give button press as higher priority. How to set this priority things? Apart from this what things i have to take care.
Thanks & Regards
stephenm
What are the two sources of the interrupt? Are you generating an interrupt from the AXI Timer?, and the GPIO. The priority on the Interrupt controller is determined by the vector position. So, the LSB is highest. So, if you want to GPIO to be the highest, then make sure that this is at the LSB:
https://www.xilinx.com/support/documentation/ip_documentation/axi_intc/v4_1/pg099-axi-intc.pdf
vikaskanha
Yes, For me two sources of interrupt are GPIO and Timer. I will stop and start my timer at the time of gpio interruppt. I connnected 0th bit (of INTR port on interrupt controller using concat)to the gpio interrupt and 1st bit to the timer interrupt.There is two concept one is normal interrupt and one is fast interrupt. what is fast interrupt . will it reduce my latency. How to infere this in my sdk side.
stephenm
Ok, so you will have two handlers; one for timer the other for gpio. In the gpio handler you can reuse the code I sent, but handle the timer here, stop, reset counter, ECT
The fast reset is discussed in ug984. Basically, it passes the vector address to the MB so it can just directly to the handler.
vikaskanha
Sir,
Now i am able to use gpio and timer interrupt simultaneously. Now i have checked fast interrupt logic mode option in a AXI-INTC IP customisation. In SDK, i wrote 0x03 at (INTC_BASE_ADDRESS +XIN_IMR_OFFSET). Is it correct.
1). If it is correct how i will verify its advantages over normal mode interrupt. My timer is giving interrupt at every 2ms.
2). SIr, i also want to reset my timer count not period  (for once  it will run with that count. )
Thanks & Regards
stephenm
Fast interrupts are not really needed in your setup. It would be more useful in a realtime app where users need deterministic interrupts.
You could measure the performance by using a scope to measure time between push button and handler.
vikaskanha
Sir, I also want to reset my timer count not period  (for once  it will run with that count). I think, i have to write TCR register for this purpose. Is it correct?
vikaskanha
Sir,
Meanwhile i am trying to add (AXI DMA + AXI-4 DATA FIFO) in microblaze. But i am not getting where to connect M_AXI_MM2S and M_AXI_S2MM.
Thanks & Regards
stephenm
